Old 10-23-2020, 11:04 PM
xb-60's Avatar
xb-60 xb-60 is offline
Firstly, if you do buy a good quality “flat” steering wheel – for example a Moto-Lita – you won’t have any problems. In fact, most, if not all of the Moto-Lita wheels to suit period Jaguars are flat, and they would certainly be strong enough.
To your question –
Originally Posted by Michael C Henry View Post
Why would a dished steering wheel version be stronger than a flat...
…. If you consider a steering wheel, with the horizontal direction being the X-axis, the vertical direction is the Y-axis, and the fore-aft direction is the Z-axis.
With a flat wheel, the Z-axis is zero length, so there is no extra resistance to a deflection of the rim in the Z direction.
Add Z depth, as is the case with a dished wheel, and you have in fact triangulated the wheel (as Gary has mentioned) in the Z direction, making it much more able to resist bending when deflection forces are applied.
Cheers!
Glen
