I have one on my manowar block with quicktime bell housing and it shifts fine. I am using the pennzoil manual trans stuff. I have had two reverse 5th rail failures not sure why. last time replacing the rail re shimmed the gear cluster it was out of spec. To be honest it is tighter now liked it loser before better but it still goes in gear at 5500 rpms no problems. All said I would still use this transmission if I were you just make sure you take your time and do it right like others have already told you.
