Old 10-26-2020, 06:59 AM
strictlypersonl strictlypersonl is offline
Originally Posted by LMH View Post
Karl, does your ERA use the two individual Wilwood master cylinders? What size are they?
I'd look into changing those to a different bore size. It can change the feel of the brakes in a big way. Maybe a phone chat with the Wilwood tech staff might lead to some ideas.
We use 7/8" (front) and 3/4" (rear) master cylinders. While we've never done it at the factory, you could change the masters to 3/4" and 5/8" at the expense of 25% more pedal travel. The other modification you can do (for only about 4% reduction in pedal pressure) is changing the caliper to Stainless Steel Brakes SSB-A185S.
