Hi Guys,
The Aviaid
Oil pan I installed on my 427FE SO also came with the the
oil dipstick tube and dipstick. I will be using the
oil tube fitting on the passenger side of pan (plugged the drivers side hole for original dipstick tube). The questions I have are does any one have photos to share of the dipstick tube installed since I am looking at how high this one sits and do you cut the tube with pipe cutter to get the desired height? Also what length oil dipstick did you use? Is using an original dipstick for a FE motor feasible or no based on how low the connection sits.
Thanks,
Rob
