Old 10-27-2020, 06:12 PM
sea2jet sea2jet is offline
Cobra Make, Engine: ERA 744/428/TKO 600
Default Stainless Specialty Side Pipe length
I’m having a new set of SS side pipes made to replace my Stainless Specialties pipes. One thing a friend noticed on ERA 727 and had corrected while they were still in business, was that the passenger side pipe was longer than the drivers side. Meaning the exhaust tip is closer to the rear wheel on the passenger side than the drivers side. I forgot to measure before taking them off and sending them to Georgie at GasN Pipes. If you have Stainless Specialties pipes on your ERA, can you measure each side to see what the actual difference is? I believe it’s just the pipe that attaches to the rear of the baffle that differs in length between the two sides. Patrick, any chance you have the same pipes? Thanks.
