Old 10-30-2020, 05:33 PM
Steve Gallegos Steve Gallegos is offline
Default fuel pump not working
I have edelbrock EFI and was trying to adjust some parameters using my hand held device. The engine started a couple of time and I adjusted the idle. The next time I tried to start it just cranked and my hand held would not turn on. Also, the fuel pump did not run when I turned the key on, I changed the relay that the pump goes to but no change. I can't find a fuse for it. I was going to run a hot wire from by battery to it to see if it turns on. Any ideas?
