Originally Posted by RockBit
sea2jet,
Sorry for the slow reply. I had to make a quick trip.
Lengths on my SS pipes (inches) are:
Passenger Driver
Nearest distance to tire: 5 1/2 7 1/4
Length after baffle: 13 12 1/2
Collector Length: 7 7
Photo is of passenger side. You can see the nonconcentric bend.
Thanks RockBit,
Your pipes look just like mine. So from a visual aspect, the passenger side looks like its 1 3/4 longer. Length after baffle is only 1/2 so I wonder if the the other 1 1/4 difference is due to cylinder offset? That being the case and depending on whether you want longer or shorter side pipes(look) adding or removing 7/8 from both the after baffle pipe and the collector should give a symmetrical appearance.
