Originally Posted by SBSerpent
One thing that I should note is that just prior to this occurrence, I had adjusted the clevis on the master cylinder plunger rod to where it connects to the clutch pedal - bringing the pedal closer to the firewall. I will re-adjust it back to where it was before this issue popped up and see if that resolves the problem.
Bingo. That's your problem.
