Old 11-03-2020, 07:24 AM
SBSerpent's Avatar
SBSerpent SBSerpent is offline
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by jhv48 View Post
Check the trans fluid level. When mine did this, my fluid level was low. Topped it off and the problem went away.
What type of gear oil is used in the trans? Mine still has the original fluid from 2011 with only 5500 miles on it. Would it be the conventional oil or synthetic that Tremec would have put in there?
Full is when the fluid is up to the top fill plug, correct? Worth at least checking the fluid level.
