Thread: Autolift 3000
Old 11-08-2020, 07:41 PM
cycleguy55's Avatar
Originally Posted by twobjshelbys View Post
The pictures here show that the pads cannot be moved. And I'll even further stand by the assertion that when fully lifted those cross members are not sturdy enough to tolerate much side-to-side motion.
If you look at this photo you'll see the left pad is centred on its mounting bolt & sleeve, while the right pad is pushed to one side. It seems clear there's some lateral movement, albeit limited.
Here the pad seems to be almost tight against the nut:
Here the pad is pushed away from the nut, with more sleeve showing:
Brian
