Old 11-12-2020, 05:38 PM
Gpkrider Gpkrider is offline
Cobra Make, Engine: Shell valley
This has worked for me before, normally the radiator has to sit higher than the engine so you can use ramps or jack it up so front end is raised, then completely fill radiator till it’s ready to overflow while evacuating the air bubbles till none are evident, put back on ground and start with radiator cap removed, run 5-10 minutes till thermostat opens, replace cap and go drive. Hope this helps
