Old 11-13-2020, 09:19 AM
6TNCRZY 6TNCRZY is offline
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
When it overheated did it push water out? Sometimes if air is trapped in the engine the temp gauge will not read properly. A good way to remove trapped air is to loosen the temp sender on the manifold near the thermostat housing. I usually drill a 1/8" hole in the thermostat and install the thermostat with the hole at 12 o'clock, this insures there is no air trapped in the engine.
