Old 11-19-2020, 12:20 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
No responses. I flooded the smaller recess with" Gorilla Clear Glue" in two stages to get the recess filled and level. I judged fluid levels by the glare off the surface. The" "Scott Drake" 1 3/8"OD emblem insert was the only emblem close in size, available. I filled the smaller recess of the horn button to form a surface even with the larger 1 1/2" recess so emblem emblem will be supported and have maximum adhesive contact area, I had to set the horn button on a canning jar lid ring so the pool of glue would sit and dry in a level position. I then covered the drying horn button with a upside down SS dog bowl I have to keep hands off and floating debris out.. The one video I found showed the clear "3M" film on back being peeled away to expose a contact adhesive on the emblem's back. Time will tell.
Mike H
