Originally Posted by CHANMADD
Leave the roll bars..Make sure there is not too much toe in the front. If the rears are toeing too much they will also cause understeer. Make sure the rears are straight, or if it's really bad and the front doesn't fix it , you can put a little toe out on the rear .
I was told to set up the rear tires a little toe in because under acceleration the rear will want to toe out... is this true?
