The best pictures that I have of the second standard design header system. CSX2055's engine after rebuild after a long storage. Note that all four iron manifolds have the AC Cars engineering number on them. (The spark plug wires are not originals. They are service replacements. O.E. secondary wires had all straight boots on their spark plug ends. Also note that the small steel adapter that got welded to the right side rear manifold for a hot air supply tube for the automatic choke is missing; most are by now. Depending on the tubular assemblies on hand the upper corners of engine stands sometimes had to be trimmed away for clearance. That was a set by set chassis by chassis issue.)
Dan Case
Reason: add detail
