Dan,
Those look quite similar to mine, with the exception that at the end of the collector I have a flange and the originals have a welded tube that carries further down and then bends out and back. It also looks like there may be extensions for the header bolts, which is nice as there are a couple of tubes that the header bolt heads scrape a little as you are turning them until you get them further seated.
Thanks.
Jim
