Originally Posted by Mongoose930
I read lots of warnings about static electricity before using the pump. I did use the ground wire and connected it to the Lemans cap flange, but I was definitely wondering how well that flange was grounded. I am hoping the aluminum body helped a bit. Anyway, I did not blow up but was a bit nervous.
Holding the lit
Lucky Strike behind your back while you pumped definitely helped.
