Originally Posted by cobrakiwi
What did all the original csx 3k cars do with there filler caps as far as ground straps go?
Any of you original car owners out there have an answer to this one?
Thanks.
All the original fiberglass cars had them.
Seriously, if the metal fuel inlet portion is securely fastened to an aluminum body, and the fuel tank itself is securely fastened to the frame via a conductor like aluminum and not leather straps, then the resistance of both those components are almost certain to be less than one ohm to the system ground. Glass cars like my ERA require a little more care.
