  #37 (permalink)
Old 12-24-2020, 08:19 PM
blykins blykins is offline
Tied to FIA rules (.060” max overbore, factory heads, flat tappet cam, factory rockers, etc.), I can make 450 hp at 7000 and 390 lbft of torque. That is not a “max effort” build by any means. 11:1 compression, non aggressive cam lobes, easy stuff.
Given modern heads, roller cam, etc., 500 hp would be easy with a 289.
RPM is a friend for small displacement engines.
If you’re focused on streetable pieces, a 289 with aftermarket heads, dual plane intake, 9-9.5:1, small hydraulic roller, will make about 310-320 hp on the dyno here.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
