As I move along with my 8 stack EFI set-up (more pics to follow) I am zeroing in on a traditional Cobra throttle cross shaft to a custom made cable conversion.
On my set-up, I did not like the pulley/capstan and solid throttle linkage arms to the throttle bodies due to the excessive angularity of the linkage arms.
So I wanted to do a cable (pull) setup which would eliminate the pulley and solid linkage arms in favor of a direct cable pull.
So here is my initial design with one cable coming from my Cobra throttle cross shaft lever to a "Y" cable connector then thru two 90 deg tubes with cables going to the throttle bodies on each side.
Attached is a pic of my idea.
Greg
