Originally Posted by t walgamuth
When I was a kid the starter button was under the clutch so you normally would depress the clutch to activate the starter. The key on the dash only worked the ignition and other stuff.
On my grandpa's truck the starter on the floor was next to the accelerator pedal so you'd push down on the gas and start at the same time. Headlight high beams ere on the left of the clutch.
