  #55 (permalink)
Old 01-07-2021, 01:37 PM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
Originally Posted by cycleguy55 View Post
I'm replacing my steering column (with dimmer switch) with one that has no switch. Replacement is going on the dash, next to the ignition switch. I thought about using a push-button switch and a VW latching relay, but have decided to go with a toggle switch and conventional relay.
They make plenty of high current toggle switches so you might be able to skip the relay. This one is rated at 25A and is sealed:
https://www.ckswitches.com/media/2301/pt.pdf
