Old 01-17-2021, 11:33 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by Voipman View Post
I have a Superformance Cobra with 351W and Tremec 5 speed. When I accelerate a little hard and then lift off the accelerator I get a huge banging/knocking from what sounds to be right behind me. I have check every bolt even removed the sway bar which made the problem worse. If I drive in a normal stuck in traffic manner it does not do it. Hoping someone else has had this issue with an SP before. Any suggestions appreciated? Also looking for troubleshooting methods.
Have you checked your rear shock mounts?
Early cars had known issues with the upper shock mounts.
Also check your rear differential mounts.
Bill S.
