Old 01-26-2021, 11:50 AM
Steve Gallegos Steve Gallegos is offline
Default brake light on vrs pedal distance
I have a backdraft,#595, when I push on the brake pedal the brake light does not come on until I am almost to the end of the distance that the pedal goes. I was told to put a external switch on the pedal arm but if I do that so the switch turns on the light, I wont be able to continue to push the pedal down to apply the brakes. Should I try to bleed the the brakes to see if the pedal comes up higher, or is something else needed?
