Old 01-27-2021, 11:37 AM
cycleguy55's Avatar
Originally Posted by cobrabritt83 View Post
I'm replacing all the shocks that came with my kit with QA1 shocks. I'm going with 450 lbs. springs in the front because of my FE block, but not sure what spring rate to use in the back. I know a lot of people have changed out the shocks from the ones that came in the kit, but what springs did you use for the rear? Thanks.
I have a West Coast Cobra with an iron-headed 460 - both car and engine are heavier than yours. Mustang II front suspension with standard length control arms. Worth noting is that both weight and angle affect spring selection.
My front QA1 coilovers have 465 lbs/in springs, while rear coils (not coilovers) are 300 lbs/in. The rear springs on the Ford 9" axle are pretty much vertical.
Brian
