Old 01-28-2021, 03:56 PM
patrickt patrickt is offline
Originally Posted by Blackbart View Post
Would it be as simple as tapping into one of the three red wires leading to the rear brake/signal light in the trunk on the drivers side to power a third brake light and if so, which of the three would be used?
Thanks in advance,
Gary
Not unless you want your TBL blinking with your turn signals. Instead, tap in to the red wire leading to the trailer relay at the base of your steering column.
Last edited by patrickt; 01-28-2021 at 04:08 PM.. Reason: In the back, the Green & Yellow are brake/TS lights; the red are for the tail and license plate lights
