  #27 (permalink)
Old 01-29-2021, 11:56 AM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Sledge,
The screws have an interference fit...Someone on the FE forum mentioned they are peened (not sure what that means). I assume so they don't vibrate loose and get sucked in and processed through the combustion magic. Only loosen maybe 1/4 turn, set idle adjustment as low as it will go. Tighten and readjust the idle position screw. I was getting a weird hang up with the engine running, but with the engine off no hang up. Maybe vacuum was pulling the butterfly plates closed where the friction occurred. I hope it helps you.
John
