Old 01-31-2021, 12:13 PM
SBSerpent's Avatar
SBSerpent SBSerpent is offline
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by spdbrake View Post
It can be either depending on what was optioned when the Backdraft was spec'd out.
To tell what you have there should be a metal tag attached to your rear diff cover.
having an "S" in front of the ratio is the LSD Id. Pics here.
https://differentials.myshopify.com/...p-differential
I can't see any tag.
When both wheels are off the ground and the tranny is in neutral, spinning one wheel does not effect the opposite wheel (i.e. the opposite wheel does not spin). However, spinning either wheel in a forward direction results in the drive shaft rotating in the same direction. Is that an indication of a LSD?
