  #30 (permalink)
Old 02-02-2021, 08:25 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Over the years I've had two clutch/flywheel failures (notice I don't use EXPLOSION) and a friend has had a starter ring gear failure-------some parts came thru dash but didn't make it thru the windshield in the first one which seems to have been caused by bolt failures with the 5/16 bolts for holding pressure plate assy to the flywheel---bolts had failed at the last thread to the shank in the recessed hole ( designed as a shear )
the other one was 64 Cyclone 289 with top loader------failure resulted in the headers being destroyed plus 2 ears broken off the top loader------and the radio------
