74proii: It sounds like you’re the right person the talk to! I’m very grateful for the input. They are 11” rotors- just measured. I went to get a caliper slide pin is what started all of this- but I really wanted to sort this out so that I know which brake kit I need to order, that will work for me/On this setup.
I guess I’m not sure if I go with something different do I need to also replace the spindles?
I have 18” wheels, so clearance won’t be a problem. The current wheels actually stick out about 1/4” too much- probably my fault when ordering the custom wheels. So if these are Granada brakes, if I switch to an Mii setup, it will tuck the wheels in a bit? I’ll have to make sure I have the clearance on the inside. Worst case scenario I guess would be spacers to set them back out.
So any Mii brake kit should work? Like this:
https://www.summitracing.com/parts/w...g-ii/year/1977
Or do I need new spindles as well?
Seriously- thank you guys for your help. I’m so close to being able to drive this car- FOR THE FIRST TIME EVER. I’m so excited.
Michael
