Old 02-04-2021, 10:48 AM
tortuga tortuga is offline
Default Numbers
Originally Posted by MKS427 View Post
What octane is recommended by the builder? What is the compression & cu in?
She calcs out at 10.8:1, 91 octane...The actual Cu in im not sure whatever the overbore is? With a 4" stroke a .02 overbore would add about 4.25 CI if my math is right so ~431 or so?
I was impressed with the numbers, i don't really NEED as much power as possible, just thought it was an interesting stable looking curve, just sharing. Its actually going to need a stouter clutch based on its torque capacity than the one i had...Fun to brag about at cars and coffee will i use it? Not really...
The impetus was to tear the motor down and put it back together right, its burned oil from day 1. I put the ported heads on just because i got a smoking deal on a brand new pair.
Seems Ford Racing uses alot of cool guy bits but falls short on the actual build from what i was told by the builder.
Superformance 1764
Ford Racing 427 SB
