Thank you for the info! Once my replacement UCA’s arrive I’ll give an update on how they fit. I guessed and went with the 375 springs as most said their ride was too stiff. Got the Mr. Gasket shock extenders to add a few inches so I didn’t have to cut and re-weld the upper U brackets! Thank you to the fellow who told me about that!!!!! Also a thank you for letting me know about the speed bleeders for the brakes- grabbed some of those too. Genius!
One thing to note, which surprised me and I’ll mention this to QA1 when I have a chance: the lower 1/2” eyelet is 85mm in length. The corresponding opening on the LCA to mount it into is 83mm. Not sure if that mistake is QA1 or Heidts, but the parts don’t fit together without modification. Just 2mm per side to grind off, but not something you should have to do really. Not a huge deal, just found it odd and had me second guessing the parts I ordered were the correct ones.
