  #27 (permalink)
Old 02-18-2021, 07:07 AM
FredG's Avatar
FredG FredG is offline
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Default Carbs
I was just looking at this dual quad setup and noticed the carbs mounted in reverse with the vacuum advances on the driver side, primary's in the rear and passenger side carb linkage with a linkage bar running in between the carbs. Is this a standard FE dual quad setup or does this particular manifold require that configuration?
Fred
