  #172 (permalink)
Old 02-20-2021, 10:53 AM
patrickt patrickt is offline
Originally Posted by CCKW353 View Post
Any words of wisdom on installing this clutch fork setup would be appreciated.
This shouldn't be too tough. Hopefully they trimmed your clutch fork corner otherwise it can scrape the reservoir cup over on the master cylinder. See my trim pic below. Also note in my second picture that some blocks, like my original iron block, need the aluminum spacer between the slave and the block. Look carefully and you will see it. You can see from the pics that I have a Lakewood BH. Quicktime BHs are a little different. This is a very straight forward install and the key to get it working right is having a nice straight alignment on the slave, the plunger, the fork, and it's path of travel. And if it ever starts leaking, fixing it is not a big deal.
Last edited by patrickt; 02-20-2021 at 10:57 AM.. Reason: EDIT -- If you have a really sharp eye, you will see the second pic was taken before I trimmed the fork in the 1st pic.
