Is it a fairly recent build? Were the heads re-torqued after the motor was broken in after a few hundred miles? I had a fresh motor blowing coolant out of the head gaskets once at high RPM's, re-torqueing the heads fixed it. Loosened each head bolt then retorqued to spec.
