Originally Posted by my427cobra
Hi ERA626. Beautiful looking EFI system you have there. And that's quite a covey of coil packs you have on the firewall.
What ignition set-up are you using?
And where do you draw manifold vacuum for the MAP sensor? A vacuum reservoir somewhere?
Greg
we are using a megasqurit...there is a port on the rear on the valley plate for the MAP vacuum tube, then it goes to the ECU. look on my build photos it shows detailed photos of this... The design is amazing.
