Old 03-01-2021, 05:25 AM
jwshira jwshira is offline
Cobra Make, Engine: Superformance, Dart aluminum block, AFR aluminum heads.
Originally Posted by Gaz64 View Post
Sounds like a harness moving around.
With the engine idling, move your distributor pickup wiring all the way up towards your 6AL, and also and wiring that can move under g force.
I would also like to know if the car accelerates well continuously, at least for 3 gears.
I'll spend some time tomorrow with wiring to see if I can find anything obvious.
Running through the gears, it pulls hard...real hard...first through fifth. It's definitely not a fuel starvation due to fuel bowl slosh issue.
