Old 03-02-2021, 08:22 PM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by RallySnake View Post
The critical thing is that the pivot points of a steering rack must line up with the inner pivot points of the upper and lower A arms. If they don't, you will have very bad bump steer problems....RS
RS is spot on there. The rack must be mounted so that the pivot points are reasonably closely aligned horizontally and vertically with the inner pivots of the lower arms/wishbones.
Of equal importance, the tie-rods (rod-ends) need to be parallel - or close to it - to ensure zero (or minimal) bump steer.
Glen
