Old 03-05-2021, 08:56 PM
cycleguy55's Avatar
Originally Posted by incoming View Post
I built my 351w and had it installed by my local guy ( I don't have a lift).
Old engine never overheated. Drove it two miles and she overheated. I suspect its airlocked.
Install a thermostat with a 'jiggle pin' the next time you drain the cooling system. It allows air to flow through the thermostat, then closes when coolant starts to flow through. Problem solved.
Brian
