brake issues ( very little pedel and no air in lines)
I replaced the hoses that are in between the master cylinder and the remote container that holds the fluid because of the hose cracking and starting to leak. the problem im having is I have bleed the brakes at the wheels and don't see any air, just fluid do I have to bleed the master cylinder also ? and if so whats the easiest way to do that. Im hoping bleeding the master will be easier than replacing the hoses , due to whoever built my car put the clamps on backwards and that was a ***** to get to them to remove
Life starts when the little needle goes past 6,500 rpm's
