Old 03-16-2021, 08:15 PM
Roylerumble Roylerumble is offline
Originally Posted by MaSnaka View Post
I bought a pair of adjustable lower control arms. I had to have them shortened and then powder coated. I also used the adjustable uppers. Heights I believe. Easy to align and set the pinion angle. Aligned and set by a shop with more expertise than I. I don't believe there are any off the shelf LCA that will work. So either locate some from the kit or make your mods to something close. I went from an 8" rear to a 9" when I did this.
John
John,
I took a look at your photos. Nice work. I wish I could find some from an old kit (long shot). I'm going to stick with the 8.8. If I have to build some, or rather have them built, I'm hoping someone can send me some decent pictures and measurements. The manual says that the factory, 89 mustang rear swaybar I believe, will work. Is that correct? I have to figure out how to accept it, as I read the factory arm passes through it.
