Originally Posted by 74proii
No none, off the shelf. As Roylerumble said the stock used a truck GM bushing. Building a new one would be easy like MaSnaka said. The only factor is size of the mounting bolt/bushing you go with. I got mine up on stands last night. i'll try and get some overall measurements in the next day or two depending on my schedule. i was personally was going to try either modifying a stock SN197 performance version like below, or a adjustable fox body like from MMR. Not sure yet which way. I have not done measurements yet, but I was leaning on trying to use Mustang rear springs (you can get weld on perches) vice the Vega or Chevette el crappo springs
you have to let me know if you're going to do the upgrade, I'll buy your lowers off you. By MMR, I'm assuming you mean Maximum Motorsports? Those ACA004 arms aren't adjustable, and what would you do about spring perches and sway bar mounts? I'm starting to think this is gonna cost me lots of cash, haha
