03-20-2021, 12:56 PM
IN
Originally Posted by Lightingrod
I modified a CRII pedal box for no throttle (electronic now) and hydraulic clutch! With only 700 miles the clutch master cylinder failed! It was a Wilwood 7/8"! This is for a GM hydraulic throw-out bearing. I didn't like the feel of it but it seemed to be moving in/out pretty straight, with no binding and I had a stop! To reduce pedal movement I replaced it with a 1 1/8" Wilwood, I like it even less!
Thinking of going with this:
https://www.jegs.com/i/Wilwood/950/340-11295/10002/-1
Thoughts?
With the 1 1/8" mc vs the 7/8" your pedal pressure should be significantly harder....is that your complaint?
