Old 03-22-2021, 02:30 PM
bobcowan's Avatar
bobcowan bobcowan is offline
It is a stock Chevette column from the early 80's. I can't remember the exact years. If you were lucky, you could find one with the tilt feature.
The hub is standard aftermarket stuff, with a provision for the horn button. I think they had 3 bolts to hold the steering wheel to the hub adapter.
To know the exact fit, you'll have to pull the hub and measure the shaft for diameter and spline count.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
