Well I just went out and screwed around for a bit. Got the switch out. Looks like it only has one position setup where the parking and headlights are in parallel. I may run a jumper and modify this so I have headlights plus parking or just parking.
I think my issue may be the dimmer switch. I have no idea what this is or what it is used for but after tracing everything out and functioning it all I have found the relay is operational and I get my positive to wire 141 which should connect to the dimmer switch. The dimmer switch should then be wired to the low beam and high beam fuse.
Does anyone know what the dimmer switch looks like, its basic operation and where it may be located? Reading back someone mentioned this earlier but I over looked it but I now believe this may be where my issue is.
Thanks everyone so far and hopefully we can get this sorted out
