  #21 (permalink)
Old 03-23-2021, 05:45 PM
eaks eaks is offline
I think I figured it out guys. It jumped around and went to a harness end with nothing connected. I point-pointed and verified I had my switched hot (from relay) and the wiring to go to both the low and high beam fuse. I did a quick test just by putting a short between the hot and low/high and everything worked as it should.
I believe I have an old GM column (not sure what it is). I think I will just install the dimmer switch mentioned by 74PROii and mount it either through the dash or somewhere accessible and out of the way.
One issue down many more to go I am sure (although this was the big one).
Still trying to decide how I want to wire that 3 position switch but will think about it and go from there. EDIT: Decided to throw a diode in and do it an easier way. Down is parking lights only and up is headlights+parking lights. Low/high will be controlled by my dimmer switch once it comes in on friday.
Thanks for all the help and I am very surprised with the responses I got from this community in such a short time frame (i expected it would go a week before anyone gave any things to try). Looks like I joined the right community.
Thanks
