Thread: Need FE heads
Old 03-29-2021, 05:03 PM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Shelby Aluminum FE Heads are cast from A-356 aluminum, heat treated to T6 hardness level and precision CNC machined. Patterned on Ford's famous 427 FE medium-raiser cast iron heads, Shelby FE heads offer leading edge air flow improvements, starting with standard 2.250-inch intake and 1.750-inch exhaust valve diameters.
Due to valve size, the heads are suitable only for Shelby 427 Alloy FE or factory 427 cast iron blocks. These heads utilize 14mm diameter, 3/4-inch reach, gasketed spark plugs positioned in the stock location. A revised design with the valve locations moved, these heads will require custom pistons. They are sold in pairs, complete or bare.
Well,new pistons are not going to happen !
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
