If your charging system is using and old school external voltage regulator make sure it is grounded correctly, not mounted on thick paint that is not providing adequate ground, solved by removing a little bit of paint beneath the mounting bolts on the regulator housing or running a separate ground wire from reg housing to a known good ground.
"...some assembly required, ages 8 and up...... well that took longer than expected......
