Old 06-18-2002, 09:44 AM
J. T. Toad's Avatar
J. T. Toad J. T. Toad is offline
Club Cobra Member
Cobra Make, Engine: Classic Roadsters, 351W -> 392
You could also try coax where you strip 27.5" of outer shielding, leaving the center wire length exposed and affix vertically (horizontally would work but vertical would be best) somewhere in the fiberglass, and connect the other end to the antenna hook up normally. Has worked in other applications.
Thought I would mention it as a worthwhile inexpensive attempt.
"Smooth seas do not skillful sailors make"
"If you can read this, thank a teacher....and since it's in English, thank a soldier."
