Good luck. Hopefully that will be the most expensive thing that you have to repair. While you have the car up you might want to check every nut and bolt, and think about changing the other fluids. If the previous owner never changed the clutch fluid there is a good chance that other things were neglected. Might as well search now while the car cannot be driven, than loose precious drive time later.
Jim
